Howdy, Stranger!
Sign In with Google
Our Sites
covecube.com
community.covecube.com
blog.covecube.com
wiki.covecube.com
bitflock.com
stablebit.com
Poll
Thank you,
Uninstalling Scanner Breaks Dashboard Functionality
edited July 2012 in Scanner
On 2 occasions I attempted to remove the Scanner Software from my WHS2011 Server and both times after it uninstalled I was unable to run the Dashboard.   The Dashboard would attempt to start then it would just shut down.  Reinstalling the Scanner Software restored functionality to the Dashboard.
The version of the software I removed was 2.0.2384.  Now I just downloaded the latest version 2.0.2467 which I will let run for a while but if I decide to remove it I fear I may have the same problem.
I am also running the Released version of Drive Pool which I am very pleased with but I am not certain if there is any cause and effect between the two which causes the Dashboard not to load properly when removing the Scanner Software.  I do have great respect for your software and believe it to be of good quality but I do need to know what if anything I can do on my end should I decide to once again remove the Scanner Software which is still in beta developement.
I am not certain if others have experienced the same thing and are looking for a solution but for now my solution is just to reinstall the software and see what if there is a solution or not.
Comments
  • Covecube
    There were a number of builds of Scanner 2.0 BETA that needed to modify the machine.config file in order to work correctly with some versions of DrivePool (including the currently released final). These modifications were supposed to be getting undone when you removed the Scanner. But a number of people had reported that they weren't.
    The end result of this was that your Dashboard would not load after you removed the Scanner. Well, as you could imagine, this was unacceptable. So we stopped doing that modification since.
    There's also a new repair task in the WSS Troubleshooter to automatically fix any systems that were bit by this.
    Available here:
  • Thanks Alex I appreciate all your efforts.
