Howdy, Stranger!
Sign In with Google
Poll
If you already have an account on this forum, then you can use your existing username and password to sign into the new forum.
Thank you,
WS2012E Dashboard problem
edited January 2013 in Scanner
Hi
I installed the latest version of Scanner 2.3.0.2832_BETA on WS2012E and lost the client Dashboard access. It was on a clean instalation of the server and I had no BPA issues. Once I uninstalled the scanner the problem was resolved.
Has anyone else had the same problem?
Comments
  • I did not loose the client dashboard, but I lost my entire drivebender drive pool. Apparently the scanner is not compatible with drivebender.
  • edited January 2013 Member
    I also did not lose my dashboard, however it is erroring as soon as it starts to scan the surface of a drive so certainly has issues.
    I allowed it to send a report, is there anything else we can do to report problems? I'd like to see it working sooner rather than later!
    I dont use drivebender so can not comment on that.
    My install is also only a few days old with no extras installed other than lights out.. which incidentally manages fine to integrate into the dashboard ;)
