Howdy, Stranger!
Sign In with Google
Poll
Thank you,
scanner can't read SMART data
edited March 2013 in Scanner
I have an LSI 9207-8 SAS/SATA PCIe host adapter card that has two 2TB disks attached.
StableBit scanner says S.M.A.R.T. and temperature data are not available for those drives.
My OS boot drive is directly attached to a motherboard SATA port and it works fine.
Any thoughts?  Is it a limitation of the adapter card?
Comments
  • Hi
    Navigate to the the scanner c:folder not sure of the full path and look for the config file scanner service config then set
    Unsafedirectio to true save and restart I had the same problem with drives smart not showing worked for me if you start to get crashes turn it back to false
