Howdy, Stranger!
Sign In with Google
Our Sites
covecube.com
community.covecube.com
blog.covecube.com
wiki.covecube.com
bitflock.com
stablebit.com
Poll
Thank you,
Using WHS Backup with Drive Pool
edited May 2012 in DrivePool
Hey guys, moved from v1 to WHS 2011 and am running Drive Pool.  So far it seems great but I do have a question.  I have 5 drives in my box, and had intended to use them in this manner:
C/D:  OS drive on C partition, D partition is for client backups and CrashPlan backups.  This drive NOT in pool
E, F, G:  all 2TB drives in Pool
H: 2TB drive purely for WHS backups
P: This is the Pool drive
When I get to the point in the WHS Backup wizard where I'm asked to pick the folders I want to backup, the Pooled drive (P in my case) is not listed.  It shows my 3 pooled drives (E,F,G) but those all contain portions of my overall data right?  Any guesses as to why the Pooled drive doesn't show up in the wizard?
Comments
  • Resident Guru
    Hi alexB, the ultra-short version is DrivePool is an abstraction layer (software) and the Backup Wizard only works with physical drives (hardware).
    You can still tell the Wizard to backup your E,F,G drives (or parts thereof) but:
    * the Wizard has a hard 2TB limit regardless of the size of your backup drive.
    * if you want to only back up certain folders within the drivepool folders on those drives, rather than all of the drivepool folders, you potentially risk missing files if you use the Wizard to do this (since it can't see the pool).
    * if you do backup all of the drivepool folders with the Wizard, it'll "double up" on duplicated folders (since it can't see the pool).
  • Member
    Thanks Shane.  That's too bad, it would be nice to be able to backup a few select folders in the pool.  I just installed crashplan on this machine and it DOES see the pool so I guess I can use that instead.  Thanks,
