Howdy, Stranger!
Sign In with Google
Our Sites
covecube.com
community.covecube.com
blog.covecube.com
wiki.covecube.com
bitflock.com
stablebit.com
Poll
Thank you,
Possible Drive Corruption
edited August 2012 in DrivePool
I was checking the WHS Alert Viewer and saw "one of more server hard drives must be checked for errors". I followed the instructions to check + repair the drive, however in doing so I was warned that it would need to put the drive offline. I was concerned that in doing so it may upset Drivepool so I tried to first remove the drive from the pool, but DP gave an error indicating corruption. I am unsure what to do, I have been running DP for over a year without any problems whatsoever. I haven't noticed any data loss, but I only access a small proportion of the data on the server.
Dashboard indicates I am running version 1.0.1.6008 of DP.
Any suggestions would be gratefully received.
Comments
  • Don't take the drive offline. Select No and then it will ask you if you want to schedule a disk check. Select yes. Reboot the server and it will run chkdsk on reboot.
