Thank you,
Hello,
I am a new user of DrivePool and hope to get some advice on what is going on.
I am moving from WHSv1 and about to get DrivePool going on Windows 7.
I created a pool and a number of shared folders and moved data into them. DP reported a missing disk and I decided to start all over. Possibly not the best choice. I moved all data out of the pool the pool, deleted the PoolPart directories and uninstalled DP.
Installing again I get the message the "One or more disks are disconnected from the pool", but no such error indication in the UI panel as I had the first time. I also do not get one of the disks reported. Windows reports it as present, but it does not appear in the Disks/Non-pooled section in the UI.
What to do?
Comments
