Thank you,
Hi There
I am having a few problems with M4. I did a clean installation and created the following folders:
Movies
TV
Music
Within each of the above folders are subfolders that contain video/music content. For example, Movies\Rocky or Movies\Rambo
I copied all of my collection over to each of the 3 folders, created my user accounts in dashboard and gave each use read/write access. However, for some reason not all the subfolders within each of the main folders have the proper access. Some of the subfolders have an image of a padlock on t hem meaning that the user accounts I created can not get access to these sub folders. I am constantly having to manually go into the pool, locate the subfolders that have the problems and manually add the user accounts I created in the dashboard into each subfolder.
Is there anyway to sort this out? It becomes a problem when you have a tv collection, with tv series, with subfolders in that tv series for each season. I am having to go in manually and check each tv series and each tv season to make sure that they are not locked and setup share permissions.
I have tried resetting the shares. Tried resetting the read/write access via dashboard but everytime I do that the same thing happens and I have to go back in and manually setup share permissions.
Is anyone else having this problem? Is there a simple fix for it?
Comments
Kind of annoying, but not critical - I haven't lost any data, so I'm just working through it for now.
- cd \ServerFolders\Movies
- Icacls *.* /inheritance:r /t
- Icacls *.* /inheritance:e /t
Do that for each of your shares.
